1 - 8 of 8 Posts
Hi, I use ever (more than 7 years) Prime95 to test my CPU OC (and I use this with Ryzen with good results but now I can't)
My PC freeze with black screen.
My PC:
Asus prime pro x370
And Ryzen5 1600 (stock) (disable core boost) (segfault CPU)
Power supply: 1200w Thermaltake
Ram g skill 3200mhz (at 3000)
Nvidia 1060 3gb
Windows 10 the last build
Now I use IBT and this morning i see more than 30 pass (I select 100 with all memory).
I don't know if my problem is stability/windows build/prime95.
PS: I test my ram with bootable memtest 7.3 more than 12 hours with all cores without errors, I don't have any error or problem in windows.
Thanks to read.
Stupid question, but are you using the latest Prime95 version?
I also had exact same problem like you and than downloaded latest version and latest version of AMD chipset drivers. Now it is working as it should.
Sent from my SM-G930F using Tapatalk
Discussion Starter #3 (Edited)
Prime95 version: 29.1.1
Windows build: 1709 (16299.402)
AMD Drivers: 17.40
I download now the latest version of Prime95 (29.4.7)and the latest AMD Drivers 18.10, i try with it this night probably.
**The AMD drivers (version 18.10) only change:
-AMD PCI Device Driver.
-Controlador AMD GPIO.**
Ps: *Pass more than 50 passes of IBT at max Ram. (Stock)
*Pass More than 20 passes of IBT at max Ram (3.8ghz)
without problem but Prime95have Crashes.
Thanks for all i post my results tomorrow.
EDIT: 3 Hours with Prime95, work good now apparently, Thanks!
No problem mate, glad l could help ;)
That's great ;)
mine a bit different
i can survive occt and prime95 for hours on my OC
but
occasionally black screen on AIDA64 (that supposed to be lighter), even at stock bios setting
no idea,
if u have some experience about this, it could be hepful for me
thanks
1 - 8 of 8 Posts
