ok my cpu is set to 333x9=3ghz.
my vcore is 1.36v
my FSB Volts are set to +2 and memory is set to +1 (volts)
my full load temps are 69 degrees
my vid is 1.26
my motherboard is EP35-DS3L.
Am only lasting for 30 mins prime95 with all the settings above exept the vcore was at 1.3v.
i tried lowering multi but it was even more unstable.
my FSB D Ram ratio is at 1:1.
am i adding too amny volts causing instability?
i really cant get stable no matter what, can you help me please?
also on prime, the workers are at different stages. 1 core will be at test 2 and the other test 3 or even test 4, is this normal?
my vcore is 1.36v
my vid is 1.26
