Originally Posted by KoSoVaR
hmm so you think thats the problem, tard? So I was probably stable at 11x250 (2.75ghz) but it crashed like after two hours of playing games.. and it just.. reset. I never changed the HT x
damn i suck
Should I go back up to 250x11?
I really want to hit 3ghz with air.. it has a Big Typhoon with AS5 on the CPU..
The memory are as follows, from CPU-Z:
FREQ: 250
FSB
RAM : CPU/10
CAS# LAT: 3
RAS# to CAS# Delay: 4
RAS# Pre: 4
Tras: 8
Trc: 22
DRAM Idle Timer: 16
any ideas?
Well theres your problem! I think, because
All amd cpu's come with a stock fsb of 200.
200 x 5 = 1000 so that's what it's stock in bios.
When you up your FSB your making your fsb of 250 multiply by 5 giving you 1250. The most upper higher end mobo's such as dfi's can take it, but it puts a LOT of stress on your mobo. So how the hell do ya fix this? Change your HT to 4 which ought to give you a perfect 1000. I'd say go with a 250 fsb, with a 4 x HT and a 11X multiplier.
In my opinion, 1.55 volts is a tad much to get a san diego to post at 250 fsb. Try what I said and prime it. If it passes, try taking your voltage down slowly bit by bit till you get it to a nice low vcore. Test for prime and if it passes, there ya go, rock solid o/c, and great temps
