Untangle Club
Protecting a network from intruders, viruses, harmful websites and other bad things can take a whole suite of software that has to be loaded up on each computer. Not only can this be expensive, but each computer suffers from having all that software running in the background. A better way to handle this would be to dedicate a single machine to the task and make it a full time Gateway(Router). If you don't have the resources for a full time gateway, there is re-route technology that allows you to run Untangle on a PC with XP.
Did I mention it's free!
Untangle Website
Screenshots
Source
Setup - if using PC as an Untangle Router
More setup options.
How to setup Untangle
- Set up computer like any other PC.
- Connect NIC1 to modem.
- Connect NIC2 to switch. (If connecting to residential gateway, disable DHCP on it and connect on a LAN port)
- Download and burn server version of Untangle .iso to CD: Download link above.
- Boot off CD and install router OS
- Enable DHCP.
- Add any addons (i.e. Spyware, Virus, Phishing, Firewall, ect)
Screenshot of Untangle
Info and guides.
- Hardware Requirements
- CD Dedicated Server Install Guide - this is good to have while installing.
- Re-Route Technology Explained
- Windows Install Guide - if using re-route technology
- Guide to Virtualize Untangle
- Quick Install Guide: Untangle for Ubuntu and Debian - not for the beginner
Untangle Users
-Bacchus451
-dhrandy - (former user, trying to save money now)
-DuckieHo
-FragaGeddon
-Frog_Racer
-gill
-kneeki
-mickmania
-Sunrex
-The.Pr0fess0r
-trueg50
-xTmDarren
-XxG3nexX
[CODE][center][url=http://www.overclock.net/networking-security/430912-untangle-club.html#post5167346][b]Untangle Club[/b][/url][/center]
Preview:
Untangle Club
Just copy and paste the whole code into your signature...
Keep in note I update daily
My Untangle Setup
Compaq Presario 6000EA
Pentium 4 2.4MHz.,
768MB RAM,
40 gig IDE Hard Drive
Integrated Intel ICH2/Kinnereth+ 10/100 Network Card
PCI Linksys LNE100TX EtherFast 10/100 LAN Card
HP CD Burner
My Network
Untangle PC
Dlink DGL-4300 - used as a switch
Desktop
My Laptop
Wife's Laptop
Server
HTPC
Xbox 360 - bridged with HTPC
Vonage
