Originally Posted by Domino ![]() You thinking the HD is more geared towards gaming with the STX is more geared towards Music where the HD can still holds it own against it? |
Correct me if I'm wrong, but isn't the SNR also worse on the front panel?Originally Posted by chalkbluffgrown;13328158
its a bad idea if your cans require a much higher impedance. Some people have no problems whatsoever with case noise being heard in their front panel audio jacks, some do. So if you are using low impedance cans and you have no case noise problems, then use your front panel.
I used an X-Meridian 2G sound card, and it has an excellent front panel headphone out conection. No noise whatsoever.
Originally Posted by DiegoAK ![]() off topic, this one says Onkyo's SE-300PCIE sounds better than Essence STX. http://club.coneco.net/user/14407/review/62673/ |
