1 - 20 of 1362 Posts
Team Skyn3t presents: Unlocked NCP4206 Voltage / LLC mod tool
TeamSkyn3t_ZawarudoABHack_B18.zip 56k .zip file
Version 4 is for use with Afterburner beta18
remove tick on "Enable low-level hardware access interface" in General properties to get voltage control working in beta 18 And set voltage control to MSI extended
Originally Posted by Agent-A01 View Post
Found a fix for voltage not working.. What i had to do was:
1. Load OC profile hit apply
2. Click the same profile to where i shows Apply as clickable.
3. Apply voltage in tool.
4. Click apply in AB.
The old steps doesn'tt work anymore for me, where you apply voltage, move any slider up and then back down and apply. But theres no way to save the voltage into a profile.
pre-requisites:
Run Afterburner & my program in admin mode. right click .exe>properties>compatibility>tick run as admin box
Afterburner 1.3v softmod & Afterburner Download
Ok, to begin with you should read everything on the program itself. There are some important points.
That a side let's crack on:
The two circles in the image below indicate whether or not your cards NCP4206 is at position 3 or 4 on the card.
An easy test to find out if your card is a 3 or a 4 is by clicking the check LLC status on the red and blue side.
Whichever side returns with:
Is the correct one. (If you have used my mod before it will return as 00.)
Simple click the Enable LLC mod on either the red or blue side (whichever one your card is)
And that's LLC enabled, simple eh?
You can test if it's worked by clicking check LLC status. It should return a 00 now.
Enter your voltage as a 4 digit number.
Remember that actual voltages are always 0.025v higher due
to the LLC mod being enabled. I've tried to get the numbers and voltages to match but the buck controller
simple doesn't have enough programmable steps for LLC.
1200 = 1225 which is 1.225v due to LLC
After you've clicked the apply button and you're sure your volts are correct head over to your Afterburner program:
Then all you need to do is move your power target down one then back up one to make the apply button click-able.
Then just click the apply button and monitor the change using Afterburners graphs to verify it's worked.
Before anyone asks, Memory voltage is still a long way off if even possible. At the moment it's not looking good.
Big thanks to Skyn3t, OccamRazor & everyone else for being total bros. Appreciated and this is for you guys.
ZawarudoABHackV2.zip 56k .zip file
<- for use with Afterburner 14
ZawarudoABHackv3.zip 56k .zip file
<- for use with Afterburner 15 & 16
Originally Posted by Zawarudo View Post
Hi everyone. I'm kevans girlfriend fiona. Kevan passed away this morning and he said to tell you that he was proud of the pictures everyone took for him. I printed them all out and showed him them yesterday and he was completely overwhelmed by your love and support.
Just know that he held you all in the highest regards and he said he regrets not getting the ti to over volt properly (I assume that means something to you guys)
A truly beautiful light has gone out in the universe that can never be replaced. Most people didn't know that he privately funded 2 soup kitchens and every year bought thousands of pounds of Christmas presents for terminally ill kids. That was just the kind of sweet heart he was, he never expected anything in return for the things he did.
He was the absolute love of my life and I miss him so much already. He passed well with a smile on his face and was chuckling right to the end, not even cancer could keep him down.
I don't know what else to say..
Fiona.
I really don't know how to begin with this post and what to say exactly.
I lost my words
I feel bad
I can't think straight
I don't know what to do now
I wish I could do something revert his situation how I wish
I wish everything for his life
I wish he could be here among us
How I wish!!!!!
but one thing I do know.
Kevan was very brave and smart. he did a lot for us and never asked anything in return.
I know is hard to admit but today he went to a better place where no sickness exist or anything bad things exist.
sadly we could not get the Ti done 'as I bold his words above" he could not get it done in time. but now he will have all the time to over volt properly all the sky angels and how many he want in many different version those angles that will save many people life. He will going to continue his journey on the other side and keep look after us. I know it he will do it.
this is the only thing I could write here right now at this moment.
Kevan "zawarudo" one day we will have that drink. Today Me and Ed will silence.
I'm the first lol , dang someone is skipping school for some hack
Discussion Starter · #6 ·
Originally Posted by Lumme View Post
Ehh.. fully unlocked would be 1,6v for NCP4206 or am I missing something here?
it is but I'm not about to destroy my card lol. 1.45v is the highest I'm willing to go and even that's too high.
Ahh.. I C.
I'we kinda dropped the whole "be-carefull-you-might-blow-off-your-fingers..." ect. It's overclockers.net - I mean common ppl.
I saw, in another thread, that you are writhing a tool to make the mem hack a bit easier - looking forward to that hence mem hacks can be a bit of a hassle - specially when new versions of AB is out and all that.
Anyway, here its 4 in the morning and I'we been benching a bit myself, but cant seem to get past the 8
Stay cool and have fun - cheers
br. Lumme
Discussion Starter · #9 ·
Ahh.. I C.
br. Lumme
Goodnight and have a good one, I'll PM you when I've got it all sorted. It's currently just bits of code and ideas and some super bodge job cheat engine stuff haha.
Originally Posted by Akula View Post
Oh i would love to be part of this.
Nothing really to test atm. The file I shared with the guys was crap in the end. A bit more work is needed, sit tight.
Discussion Starter · #13 ·
Not if you have restraint when using it. You could use it to get a constant 1.21v or even a bit higher. I'd say you could go to 1.250v or a bit more on stock probably.
Discussion Starter · #15 ·
Originally Posted by Alatar View Post
Works on Titans?
Any further testing yet?
Any info that we need to know before trying? (aside from the obvious "dont blow up your card")?
Works on Titans. Everything is covered on the program tbh. Just a few basic things thrown together until I develop this further.
Running it won't do anything extreme, just be mindful of the voltage figures you enter lol.
Discussion Starter · #17 ·
Originally Posted by tinuz97 View Post
Nice tool m8!
I think i am going back to stock bios, and use the tool to enable 1.250 volt.
To have any voltage over 1.21v you have to use a custom bios as there are limits built into the stock ones that's as far as I know.
Skyn3t will have better info about that since he's the bios wizard.
Correct, but i do not need to high clocks for 24/7 use.
For 3dmark i use custom bios.
