[Updated] Antec 300 Mods
1283 Views 3 Replies 4 Participants Last post by  waverider599
Hey guys, been working on my antec 300 case. I cut my fan grills out, working on some cable management holes, and just installed my window today. Used Lexan from Home Depot, Double-sided mounting tape, UChannel from McMaster, my Dremel, and my Ryobi Jigsaw. I've been pondering about adding some paint, going to buy some nice blue thumbscrews for my expansion ports and get some cathodes in the system. Any comments / ideas appreciated.
Update: Painted my case, flipped the power supply, and cut holes for cable management.
1 - 4 of 4 Posts
Looks good, I like the positioning of the window.
Looks pretty sweet bro, I'll talk to you on vent later about how exactly you did it. I really want to mod my 300 with a winow over the summer.
On thing though -> Wire that CPU power plug behind your video card, it'll look a lot better.
1 - 4 of 4 Posts
