How would you rate this as a budget gaming PC?
  • 1
    Votes: 0 0.0%
  • 2
    Votes: 0 0.0%
  • 3
    Votes: 0 0.0%
  • 4
    Votes: 0 0.0%
  • 5
    Votes: 5 35.7%
  • 6
    Votes: 2 14.3%
  • 7
    Votes: 0 0.0%
  • 8
    Votes: 3 21.4%
  • 9
    Votes: 4 28.6%
  • 10
    Votes: 0 0.0%
1 - 20 of 32 Posts
This is my rig, been building it since July, piece by piece, dollar by dollar.
I am very happy with it right now.
any other info? do ask (its the sig rig)
561
that is my system (cpu 30%, gpu load) my cpu load temp is about 40C
and yes i moved the heatsinks off of the chokes and onto the mosfets.
pics
400
400
400
400
400
please rate, give suggestions and the like.
no major upgrades planned until the piledrivers come out.
i bought some blue LED lights and ill probably purchase some used promedia 2.1's (i gave my old ones to my friend, for a good reason) so I'm using cyber acoustic ones now.
id like to see what you guys have done for sub $1000 pc's too.
Originally Posted by rubicsphere View Post
That case is beautiful great choice
I agree. I chose it over the Corsair 600T white, and I'm glad. this case has an amazing look and a lot of great features, for $70 less
Originally Posted by K62-RIG View Post
looks the bomb mate, congrats. You have lots of free space in that case for mods.
yeah i need a new CD drive too, my old one was IDE
A ssd or a 1TB data drive would be nice, my current 1TB is slow and external.
any suggestions for lights?
Discussion Starter · #6 ·
i've finally modded my Lancool PC-K62 to where I want it so I won't be ripping my rig apart for a loooong time.
i kinda enjoy that part haha
but i had long screws holding on the left radiator fan, which was the stock 120mm, i mounted it before my mobo.
i needed to put my 140 mm back up there to light the case, and i swear it took me 25 minutes to remove 1 screw. geeze
Since July? Must feel really good to finally have it put together and using it. Case looks great but what's the point of using the old CRT monitor?
Discussion Starter · #9 ·
Well ive been building it and replacing parts (i started long before that with an emachine's prebuilt that was crap (athlon 64 x1 @2.4 GHz, 1 GB ram) then my friend gave me a 4350 he had ( i gamed on this, 640x480 lol), and then he gave me his old phenom II dual, i bought 2 GB ram and he upgraded from a 4650 to a 6870. I landed on the same set of parts for a while (phenom II x6 1035T cpu, foxconn am2/am2+am3 mobo, 2 gb ram, 4650. the phenom II didnt work right in my mobo so i downgraded to a quad (dumb decision, id have a hexacore now if i hadnt). and then upgraded from there after i got a job.
the CRT is for my zune mini player, breakaway, temp monitoring, weather, and is helpful while skyping.
I had it already, and i saw no reason to get rid of it. the extra space is very nice.
yeah modding is gr8 fun. I have run out of ideas at the moment for any more mods to my chassis but I think that will be short lived.
same here. i'm already looking into more stuff lol
Wow that's a long list of upgrades :/ looks like you have a pretty good setup right now though.
Discussion Starter · #11 ·
yeah. i made a lot of silly purchases.
but i didnt buy a part (other than 2GB used ddr2 ram) until i got the foxconn mobo months later.
i didnt know much about computers then.
Haha yeah I know the feeling because I just built my first official computer back in may last year and it's pretty decent now that I have it mostly finished but it took a ton of research to find the best parts for what I wanted to do with it.
Are those MOSFET heatsinks?
Cause, um.... you sinked the chokes (which are simple heat coils and are not fragile), not the fragile MOSFET transistors themselves (chips to the left). That's uh... other way around
If anyone would like to see a great budget rig, you could check out my primary PC in my sig.
It's probably got closer to ~$2000 worth of parts in there and ehhh it really wasn't supposed to be a budget build, buuutt.....
No.2 in Gaming
hello all,
my rig is cheap and runs battlefield 3 on high settings no problems,cpu ,mobo and ram cost just £260
,i know intel are better ,but at what cost?
Originally Posted by MrPerforations View Post
hello all,
my rig is cheap and runs battlefield 3 no problems,cpu ,mobo and ram cost just £260,i know intel are better ,but at what cost?
i built one like that..makes a great budget gamer!
but i did OC to 3.67
..only diff is i used an m4N78 pro
OP ..as xd noticed..you sinked your chokes and not the vrm chips..you should fix that..
Other then VRM-sink FAIL..i think it's a nice little build..and will run anything you need it to snappily
Discussion Starter · #18 ·
thanks! still learning.
fixed! (dnt have the camera i used anymore tho, borrowed it.)
Discussion Starter · #19 ·
hello all,
i like my mobo. it was only $55!
but yeah it still maxes out every game ive tried at >40fps. very steady
Discussion Starter · #20 ·
Originally Posted by derickwm View Post
I. Am. Terrible. At. Budget. Rigs.
Its a lot of planning and a lot of comprimising.
1 - 20 of 32 Posts
