upgrade cpu or gpu
452 12
hey I got about $700 and in not sure if i should upgrade my cpu or my gpus.
my cpu 4ghz and a 2.75ghz nb.
my gpus gtx 460s 768mb 900core
im looking at an i7-3770k and ASUS SABERTOOTH Z77
or should i upgrade my gpus to a EVGA to a gtx 680 4gb?
thank in advance.
1 - 13 of 13 Posts
I would say CPU first and then gpus later when you have more cash. The 3770k is a nice processor and will last you a while. That SLI setup should keep you close to max on most games for at least another year I would say. Get yourself a nice new cpu and mobo and call it a day.
Programmer
I mean, maybe do both? You could buy a 3570k + a decent motherboard for around $350, and then get a 7950 or 660ti for $300. All of which would be a great increase in performance for you.
Edit: I forgot about the Microcenter $50 savings. That's even better!
Programmer
Originally Posted by rchpi36 View Post
I actually need the i7 for my animation work. so the 3570k will not work
Correct me if I'm wrong, but doesn't having a faster GPU make animation work faster vs having a fast CPU?
4 threads that do much more work per cycle than your Phenom and a huge pump in GPU power will help you around the board.
Encoding/ rendering will use cpu.
Programmer
Ah! Okay, then it would probably make more sense to spend your money on a CPU if you're in need of better rendering speeds!
BTW, if there's a Micro Center store near you, $289 for a i7 3770k, if you pick it up in store.
And still get the $50 off. Save another $100 and still get the 670.
Or if you're paying the bills with your work, go X79 and 3930K like the big boys
Not New to OCN
Sell your old gear to help fund the new. Get CPU and GPU!
Well If I were you I would go for the 680. Your processor might bottleneck it a little but you can always upgrade that later (and maybe switch to intel?).
1 - 13 of 13 Posts
