1 - 20 of 23 Posts
hi guys.. i was wondering if u can help me with decision...
i have pny 8800gt 512mb 256bit...
i was lookin for some ati 5xxx series with 256bit...
but, one of card caught my eye, and its 5770 1gb gddr5 but it has 128bit...
i know that will affect performance in games since im playin them...
so, do u have any recommendation for new gpu that will hold for longer...
why not wait a while. amd is gonna release their 6xxx series cards soon. i think theyre gonna release their low end cards this year and high end cards next year.
Data Recovery Engineer
Um... the 5770 runs just fine on a 128bit interface and hits up with a 4870 just fine. Don't judge a card on its memory width alone. Read some reviews and see what your up against before you make a decision. That is how I settled on 2 5770s.
Also we need your specs of your system!
If you want something that will hold out for a while, grab a 5850 or something, but your system needs to have at least a quad for that to NOT bottleneck.
Discussion Starter #5
what do u mean to wait for 6xxx cards, to wait for 5xxx get cheaper or???
im not turbo, mega, maniacally obsess with performance in game, i just want to run it smoothly... like 8800gt, never had any problem with it and i could play any game, and still can on high defs...
I haven't read anything, I'm in school and in a rush. But I would want to know more about your PSU.
everything up to 150€
Not sure what that is in $. Might wanna look into a GTX460, though.
I Love this Hobby!
I went from 8800 SLI to 5970.
If I was you, with that power supply of 500W I'd stick with a 5770 especially if your monitor is below 1900x1200 as a 5970 would not be utilized to it's full potential.
it should be around 200$
For that price, GTX460. Hands down. Assuming prices are similar to the US.
Id honestly go for the nvid 460 right now. It's a little more expensive than the 5770 but performs better, right now its the price/performance for sure. It also doesn't take very much power (neither do the 5770s) so if you're just getting a single card your current PSU should be ok to run either of them.
OG AMD
The 450 is not as fast as 5770,and the drivers work fine.Mainly ATi crossfire have had issues.You can find good deals on a 768mb 460,that's probably the better deal right now.That card outperforms the 5770
ASUS Direct CU 460$179. shipped
The 1 Gb is better,probably worth the extra $45.
If you plan on overclocking-the Asus and MSI are best because of voltage controls.
1 - 20 of 23 Posts
