1 - 20 of 22 Posts
I have decided to upgrade from my venerable x850xt. I am looking for the best video card in the approximately $200 price point. My monitor supports up to 1280x720 resolution. The games that I will be playing are CS:S which runs pretty well right now but not at max settings, Call of Jaurez, Company of Heroes, F.E.A.R., and Oblivion. So factoring in overclocking I would like to know what the best card I can get is. Noise production doesn't make any difference to me. I have been out of the loop for a while in terms of hardware so I have no idea how well the new cards overclock.
Old school
AGP or PCI-e?
7600GT's are very fast cards, should be a little faster than your X850 and it will have SM3, so much better image quality. Another option to consider would be waiting for good rebate on a 7900GT (sometimes as low as $229). With a voltmod, the 7900GT's can overclock to insane speeds (sometimes 1700mhz memory), but you'll need an aftermarket cooler for the voltmods.<br />
<br />
Both of those cards are available in PCI-e, but only the 7600GT comes in AGP.
Discussion Starter #4
I have PCI-E and I am not going to get a 7600gt because it doesn't offer substantial or any performance gain in most games over an x850xt so to me it isn't worth $150 just for SM3. Thanks for the suggestions though. I have not seen a 7900gt that is going for anywhere near $229 with a rebate so could you give me a link please.
Old school
A 7900GS goes for around 200$ and sometimes less, and most of them overclock to 7900GTX speeds. However you have half the ram then, and 4 less pipelines and 1 vertex shader less. Still good value for money though.
Discussion Starter #6
Yeah I was looking at the 7900GS. If they overclock like you say they do then that seems like a great deal at $200. Anyone else have any overclocking results from that card?
Old school
<tr>
<div>
Originally Posted by <strong>Malaziel</strong>
</div>
<div style="font-style:italic">Yeah I was looking at the 7900GS. If they overclock like you say they do then that seems like a great deal at $200. Anyone else have any overclocking results from that card?</div>
</td>
</tr>
</table>
</div><a href="http://www.tweaktown.com/reviews/945/3/page_3_the_card/index.html" target="_blank">http://www.tweaktown.com/reviews/945...ard/index.html</a><br />
<br />
Scroll down.
Reactions: Malaziel
Discussion Starter #8
That is some incredible overclocking without volt mods or aftermarket cooling. Was that a rare occurance or can they all overclock like that?
Old school
<tr>
<div>
</div>
<div style="font-style:italic">That is some incredible overclocking without volt mods or aftermarket cooling. Was that a rare occurance or can they all overclock like that?</div>
</td>
</tr>
</table>
</div>No they also got a review of the Palit 7900GS reaching the exact same clocks. It comes bundled with DTM Race Driver 3 if you are into racing games.
Reactions: Malaziel
nope, the G71 is a monster overclocker, and the 7900GS is a great deal. The X1800XT is good, too.
Keep your current card. I don't see how a x850xt cannot max CS:S...unless you insist on 8x AA, 16x AF @ insane resolutions.<br />
<br />
Edit: I see you have Oblivion in that list. In that case, a x1900gt/7900gt should be the minimum.
Discussion Starter #12
I am not going to keep my current card as I am not happy with its performance. I can max out CS:S on my card but it does not net me what I believe to be playable framerates for competative online gaming. I consider framerate dips into the the 30s to not be acceptable. With CS:S at max settings with HDR I get about 20-30 fps on Militia and Dust with dips into the teens and this is not playable to me.
<tr>
<div>
</div>
<div style="font-style:italic"> With CS:S at max settings with HDR I get about 20-30 fps on Militia and Dust with dips into the teens and this is not playable to me.</div>
</td>
</tr>
</table>
</div>How is that possible? It must be a driver issue or something. You running it at 1280/720 right?<br />
<br />
I know for a fact a x850xt is substantially faster than a 6800GS in source games, and mine maxes them out (1440/900 w/4xaa & 4xaf) with an average of 50-60 fps on the HDR maps.
Discussion Starter #14
Well that has happend with all the drivers I have ever installed for this card. From Cat 6.3-6.9 and the Omega drivers. My computer just seems to run slower than it should everyone tells me this. I run 43 seconds in SuperPI with a 2.6ghz overclock. I have no idea why it does. Nothing seems to be wrong with it. I have run registry fixes, run good virus protection, and scan for spyware.
1st) somethings wrong with your your vidcard or pc or something because x850's are very PLAYABLE for competive play.take it from me homie.<br />
2nd) save yo money for dx10 because your card is good nuff for source.
<tr>
<div>
</div>
<div style="font-style:italic">I am not going to keep my current card as I am not happy with its performance. I can max out CS:S on my card but it does not net me what I believe to be playable framerates for competative online gaming. I consider framerate dips into the the 30s to not be acceptable. With CS:S at max settings with HDR I get about 20-30 fps on Militia and Dust with dips into the teens and this is not playable to me.</div>
</td>
</tr>
</table>
</div>Get a 7900GT. At my max non-voltmodded overclock, I got no less than 50 FPS on any map at max settings and 1600 x 1200.
1 - 20 of 22 Posts
