Thanks for the replies!
Yeah, waiting for a few months later to check the new stuff out before deciding on what to do next would be a smart move after all. Because at that time, chances are that there will be price drops on the older items (hence I'll save money) or I get the new stuff instead of the older ones. But, I'm just.. impatient like that.
I just made a list via scan.co.uk:
- Intel i7 920, D0 SLBEJ S1366, Bloomfield, 2.66 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail
- Asus Rampage II Extreme, Intel X58, Sok 1366, PCI-E 2.0, DDR3 1600(OC)/1800(OC), SATA I/II, ATX
- 6GB (3x2GB) Corsair XMS3 DDR3, PC3-12800 (1600MHz), 240 Pin, Non-ECC Unbuffered, Classic, CAS 8, XMP
- 2x 1TB Seagate ST31000520AS Barracuda LP, SATA 3Gb/s, 5900rpm, 32MB Cache, 5.1 ms
- 1792MB Gigabyte GTX 295 55nm, 2000MHz GDDR3, GPU 576 MHz, Shader 1242 MHz, 480 Cores
- 850W Corsair TX Series ATX, 4x PCI-E/ 8x SATA, PS/2 PSU
Are all of these okay? I'm now unsure about what kind of case to get, and what kind of cooling to get. My case is kind of small, so I don't expect it to fit the better graphic card (heard it's a big card). I'll be expected to overclock this rig, and that's why I'm here!
Will this motherboard support the newer processor / newer graphic card when they come out? If not, then I'll definitely change mind and buy the newer motherboard that support them when they come out instead.
Thanks again, guys!
