1 - 9 of 9 Posts
Initializing...
Currently have the Corsair TX750W running my two cards but should I get a bigger one like a Corsair 1000W or 950W? Since Fermi is coming I might sell my two cards and get a GTX 480. Just wondering if it will be enough to handle it.
You'll be fine. There is no way a single GTX480 is going to need more power than you can supply with that PS. Unless it is a 4 slot solution that requires 4x8pin power adapters and 2 PCI-e slots.
Besides, your CPU is pretty power efficient for what a beast it is and you're already running SLI 285's which aren't exactly teatottlers in the power department.
Here you go
"Another interesting fact is the recommendation of power supply units. Apparently Nvidia recommends 600 watt with 42 ampere on the 12 volt rail. 8- and 6-pin power connectors have been seen on the pictures already and aren't a surprise anymore. Furthermore the VRAM amount of 1.5 GiB has been confirmed."
From http://www.pcgameshardware.com/aid,7...sumption/News/
GTX480 uses one 6-pin PCIe and one 8-pin PCIe connectors and it cannot draw more power than a pair of GTX285s.
Your TX750 is pretty enough to handle one GTX480.
the gtx480 uses 295w, that is far less than 2x gtx280 and similar to 1 gtx295, you should be fine.
Reactions: Anth0789
As everyone has said, you will be fine. Those 750's are beasts.
Reactions: Anth0789
Initializing...
Discussion Starter · #8 ·
+1 to everyone I guess I have nothing to worry about.
1 - 9 of 9 Posts
