Upgrade to Q9550???
604 12
I am in the need for a new processor and i want a quad. Should i get a Q9550. Money is a bit tight. im at $0 after i sell my 2GB of memory and my high overclocking E6600 forl ike 125 - 145 on ebay then ill be closer. But should i get a Q9550. If i can Bust out a few more bucks i might get a Q9650
1 - 13 of 13 Posts
Q9550 over the Q9650, both get great overclocks just make sure you get a E0 stepping.
Discussion Starter · #6 ·
Originally Posted by MCBrown.CA
Q9650 is not worth it over the Q9550, IMO.
Lots and lots of Q9550 are hitting 4.0GHz or higher with the right motherboard. Basically the Q9650 ensures lower temps, lower vCore and a 100-300MHz higher OC compared to the Q9550.
ok. could i hit 4.0 with my motherboard tho??
Look for sSpec # SLB8V.
That or the spec number on the box sticker. I never heard or experienced the box sticker lying.
1 - 13 of 13 Posts
