Upgrade to SSD question
478 Views 8 Replies 6 Participants Last post by  MGlBlaze
Alright, it's been ages since I posted here (like anyone would notice me of all people being absent) but here goes;
It's been a while since I've done anything with my main rig and I know that my HDD would be holding it back a fair bit, so I'm considering getting an SSD over christmas to crank the performance up way more.
I'm going to have my OS and my games/programs on the SSD while I use the HDD I already have as a storage drive.
This is the SSD I was considering, since it seems like it has good performance and storage for a decent price, and is pretty attractive to me since it seems to have a fast write speed too;
http://www.scan.co.uk/Products/128GB...-Write-200MB-s
My main question would be if you people have anything better I could do in mind, or does this look like it would serve me well?
1 - 9 of 9 Posts
looking at your specs the only weak part of your system is your storage setup.
if you want fast loading startup etc...then go SSD just avoid jmicron controller ssd's
I'm also going SSD's this christmas as an upgrade. It's finally time to dump my 250's and use them for another storage hdd's
Random read/write performance on Samsungs is nothing to write home about... can you find an Intel-based drive or a Vertex "clone" for around that much?
Originally Posted by Lysdexik View Post
X25-M all the way.
Thanks for the suggestion, and it looks damn nice, but I'm a little apprehensive of spending £500+ on a storage device.
Okay, since the Samsung doesn't seem to be such a great idea after all, I've looked around a little more on Scan and found some other ones;
This one from intel - looks promising but the write speed seems a bit slow, though I'm not sure if that's slower than a HDD would be. Slightly on the expensive side too, but nothing completely unreasonable. (Besides, these are SSDs, and they're going to be fairly expensive anyway)
This X128 from Corsair. According to the specs it has a much faster write speed and is at about the same price point. As far as I know, Corsair's a reliable manufacturer, too. Not as high a capacity as the intel choice, though.
Either of these seem like better choices?
They're both much better; the Corsair uses an Indilinx controller (which is uncommon as most of them have Samsung controllers afaik), and combined with that it's a better value than the Intel drive (even with less capacity). Can't go wrong with either one, honestly, you'd be just as well off being blindfolded and randomly picking one of the 2.
just depends if you want speed over storage
SSDs are really fast, but don't have allot of space on them (unless your willing to spend thousands of dollars), i would get a small one for the Operating Systems, and use a 500GB or 1TB hard drive for Media / Programs
Thanks for your feedback. Personally, I'm leaning towards the corsair SSD right now thanks to the much faster write speed while only taking a very small hit on the read speed at the same time.
Besides, 128Gb should be plenty of space to hold my OS, games and various programs as long as I put everything else on the 500Gb drive I already have.
Yeah, It's hard to miss that SSDs get obscenely expensive past the 128-160Gb mark. Actually some of them are really expensive even at that point depending on the manufacturer and the performance of the drives themselves.
1 - 9 of 9 Posts
