Originally Posted by halifax1 ![]() Link You're going to need to get an extra HDD casing, or use the 20GB one that you own, because it's just the drive preformatted. I'm about to purchase one, and connect my drive to my PC and extract my files, and then load the new drive and copy the files back over. Honestly I know what to do so it's a lot cheaper and easier, but if you don't know much about using Xplorer360 and connecting your 360 drive to your PC then you'd be better off buying the original Microsoft 120GB drive, but that's too expensive for me. |
Originally Posted by SeanEE89 ![]() No I already know that I cant use an external drive like that. I have an enclosure so I can format the 120GB drive I'm going to pick up and so I can transfer over all my data. I watched the tutorial from one of the links that someone already posted in this thread. I hope that it is a good example of how to work Xplorer360. I posted the link below if you wouldn't mind checking it to see if it looks like it is a good example. I can also just pop my 20GB drive back into the xbox 360's enclosure if I have trouble with the 120GB cant I? http://www.infobarrel.com/How_to_Upg...360_Hard_Drive |
Originally Posted by halifax1 ![]() I'm not sure if all drives will work. I know the WD BEVS drives work with Xplorer360 and those are able to be formatted but it depends what drive you are getting. http://www.instructables.com/id/Upgr...d_drive_CHEAP/ There's one link concerning flashing and formatting the drive to work on the 360. |
