After upgrading my rig I am just dying to go all the way with it.(insert bad pun) I have 2 23 inch monitors with DVI connections. I want to upgrade my video card to hande Eyefinity and get a 3rd monitor. It gets a bit confusing on what connections are required to make it all work so I figured I'd just ask.
Can I use my 2 monitors(DVI), add a 3rd(HDMI) and get a 6850 to run the Eyefinity? More directly, will I be able to use 2 DVI and 1 HDMI to be compatible? No other special adapter cables required?
And perhaps a better recommendation? Under $240 if really a big difference over 6850.
Was thinking about putting a larger 27 inch in the middle also. Does this throw off perspective too much to be playable with games?
Thanks for any help! Looking forward to getting more involved in your site. I'm just having too much darned fun with my new i7!
Buddy
Buddy
