1 - 3 of 3 Posts
I'm looking to upgrade the LCD in my laptop to one with a higher resolution but I have a few questions before I order one.
I can't find any specific replacements for my Gateway but I find all the generic ones on ebay, are all the mount points the same for each brand?
Also, most of them on ebay don't come with the inverter, will the one in my laptop support a different LCD screen or would I need a new one?
Thanks
Heres what I'm looking at.
http://cgi.ebay.com/GATEWAY-NX560XL-...1|293:1|294:50
I would Message the Ebay seller, as it says in the listing they Garuntee 100% compatibility.
So message them asking if that LCD will match your laptop, as it seems they have a list on what parts go to what.
As for the inverter. I'm not 100% sure, but I think you need those to come with the LCD.
I've only had to replace a laptop LCD once, as that was when my friend dropped his and it broke so we went on ebay and just bought a "Kit" of his laptop which was LCD + Case, you had to buy the parts.
1 - 3 of 3 Posts
