1 - 5 of 5 Posts
I would like to upgrade my mobo to one that has better features for overclocking, and an additional PCIe slot so that I could crossfire, but I'm not sure how exactly that would work. I've never replaced the mobo in a system and from what little I've gathered Windows will not be very cooperative if I switch out the mobo. All help is appreciated, thanks
I'm assuming you must have OEM Windows then? Yeah, you can call Microsoft directly to get it re-activated I think. Shouldn't be a problem as long as you kept all the stuff that came with it.
Are you also looking for suggestions on a better motherboard or were you just wondering about how to re-install your windows oem?
Yeah, I have the OEM Windows. I was just clearing things up about having to re-activate Windows and stuff if I switched mobos.
1 - 5 of 5 Posts
