1 - 9 of 9 Posts
Want to upgrade from dual core to a quad core which of these will be the best upgrade I mainly play games on my pc.Here is a list provided by HP
This motherboard supports only AM3 processors
Memory support is limited to DDR3 modules only.
HyperTransport 3.0
Split power planes allow separate power management for CPU and integrated memory controller for improved power savings.
Supports the following processors:
AMD Phenom II X4 9xx/9xxe/8xx Quad-Core (Deneb)
AMD Phenom II X3 7xx/7xxe Triple-Core (Heka)
AMD Phenom II X2 5xx (Callisto)
AMD Athlon II X4 6xx/6xxe (Propus)
AMD Athlon II X3 4xx/4xxe (Rana)
AMD Athlon II X2 2xx/2xxe (Regor)
What is your Mb?
pegatron M2N78-LA(VIOLET6)Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Chipset: NVIDIA GeForce 9100
Memory sockets: 4 x DDR3
Front side bus speeds: 5200MT/s (5.2 GT/s)
Processor socket: AM3
Expansion Slots:
1 PCI Express x16 slot for graphics card
2 PCI Express x1 slots
1 PCI slot
1 PCI Express x1 minicard slot
What are your current cpu?
Phenom x4 900 series would be the choise. 975? Or one of the others
Originally Posted by wrsj77 View Post
My current CPU is a Athlon II X2 240 2.8GHZ
Well, its has to be an phenom II x4 900 series then. Would be an great upgrade. the 975 is delivered at 3.6GHz, but the other would be able to hit same speeds whit some cooling, making them just as good, but to a lower price.
Yes,phenom x4 925 is a good chooise. Then oc it:)
1 - 9 of 9 Posts
