So I'm re-freshing my Gaming Rig soon, and I need to choose a new GPU Card.
I'm going with a Triple-Monitor setup and I'd rather not spend 1000$ on dual GTX 580s for a tiny performance boost over a 6970 CrossFire Setup, and and the GTX 590 seems to be almost entirely sold out, which leaves me with:
AMD Radeon 6990
CrossFire AMD Radeon 6970s
A friend of mine is recommending SLi GTX 560 Ti, but slightly less performance.
GTX 570 SLi?
I've read some comparison reviews (here and here), apparently the 6970s CF are less noisy and seem to pull ahead of the 6990 sometimes, especially with AA, and the Review says that the 6990 will in the end offer better performance than a 570 SLi setup.
Having never used one, I'm not sure if the Dual-GPU Cards can run into the same problems as CrossFire Setups (lack of support in the game etc), so I'm stuck at a point where I need some advice, maybe someone has some experience with any of these setups?
Also, recommendations for Manufacturer? Sapphire, Diamond, Asus?
Cheers
AMD Radeon 6990
GTX 570 SLi?
Cheers
