I personally use xvid avi, and have never had a problem with it.
If money is an issue, you can use VirtualDub
Originally Posted by crashdummy35 ![]() Okay. I guess I'm off to study Xvid. I wish Vegas could render to .mov .... would save me a ton of trouble here. |
Originally Posted by Coma ![]() There really is no relevance to the actual format you upload to YouTube, as long as it's not something extremely proprietary that it can't convert. Basically, everything ffmpeg can handle, YouTube can handle. The only thing that matters is the quality. Or in your case, preserving what you already have. Just do your thing, then export at some gigantic bitrate. The encoder/codec really doesn't matter, just use some ginormous bitrate. 15Mbps or higher. Doing it right only matters when other people are going to be downloading it directly (get the same quality for less size), or if you're trying to conserve bandwidth of time. But if you have an OK upload speed and a sane bandwidth limit, you really shouldn't care. If you want to do it right (not recommended, just do it the easy mode way): you can deinterlace it in Vegas and export it to a Lagarith AVI (google Lagarith), then use this to convert to mp4, and upload that. I can't be bothered explaining everything so just search around. I've probably said everything you need to know already, just search for the pieces. They're all in this sub forum. |
