Originally Posted by ATVkid*AFZ* i'm looking for a cheap UPS with line conditioning (you know, cleans the power before it sends it to my PSU... anyone know of any? |
Originally Posted by archer_456 $39 ---> http://www.newegg.com/app/ViewProduc...101-124&depa=0 $59 ---> http://www.newegg.com/app/ViewProduc...101-128&depa=0 |
Originally Posted by ATVkid*AFZ* thank you sir...now these have line conditioning? |
Originally Posted by archer_456 I'm not positive if they a dedicated conditioning circuit, but since they use huge capacitors (for the battery back up), you will end up with clean and constant power. Thats just how cpapcitors work. You won't have to worry about spikes and/or surges. |
Originally Posted by setite whoa wth are you talking about... are the effects of line conditioning anywhere near as important and/or effective as the things for ram.... in other words... is there any reason why i should consider a better surge protector and perhaps battery backup than i have now? |
Originally Posted by ATVkid*AFZ* basically what i want is line conditinoing. what this does is take outside power, which is considered "dirty" and "Clean" it into a pure sine wave, you know the things you made on grafing calc's, right? the one that looks like a wave... that's what "pure" power is considered, and i'm hoping to make my PSU more stable by getting one of these. |
Originally Posted by shermstix I have this APC UPS. It works wonders on my homes filthy power. I would highly recommend going with APC. They are highly reliable and are rated for industrial use. Plus their batteries are readily available. The reason that you want line conditioning is because the power comming into your home must travel quite a distance and run through many transformers to get to your wall socket. Then, the more stuff you hook up to your outlets, the dirtier it gets. Not to worry though, most QUALITY PSU's have built in line conditioning. If you want the purest power going to your components, get a UPS. |
Originally Posted by ATVkid*AFZ* @ nayo, i'm guessing level 2 cleans it more...good finds! |
