1 - 3 of 3 Posts
Science
i have a 5900se , and was told that the artic cooler verison 3 revision 2 would fit so i bought it AND IT WONT FIT. HELP me maybe i am just stupid!
Administrator
Well the Cooler that you where Suggested here : <a href="http://www.arctic-cooling.com/vga2.php?idx=39" target="_blank">http://www.arctic-cooling.com/vga2.php?idx=39</a><br />
<br />
Is actually for the XT version of your card thus wh may not fit <br />
<br />
This one here may be a better suit not to sure though : <a href="http://www.arctic-cooling.com/vga2.php?idx=56" target="_blank">http://www.arctic-cooling.com/vga2.php?idx=56</a> <br />
<br />
Im not expert so there may be an inexpensive way to fix this..
Science
i have thought of it except i need to drill down or cut 3 little poles that went through the hoels and tied down with a bolt, but also the heatsinks for the RAM is also i nthe wrong spot so i might just buy the zalmann fatility
1 - 3 of 3 Posts
