1 - 4 of 4 Posts
After I installed my waterblock last nite, I cant play games.
Furmark works fine but when I try to play games, it will try to start the game it will either stay black, or exits to windows and says:"Direct X encountered a problem." or sometimes restart
I did the clean install of the drivers and I recovered my OS still same thing
I even changed my CPU, NB to the stock clocks still nada..
Is it dead?
you installed a waterblock on the HD 5970?
Might have the cold bug. I've seen a few with it.
Reactions: sti-06
Yep,
Edit: found what cold bug is, Th only way to fix it is to create a profile with higher idle clocks?
I increased the idle clocks and it fixed the issue. Boy was I scared.
Thanks +rep
1 - 4 of 4 Posts
