well today i got everything for my new pc,and all went fine,till i plugged it in and it ran fine,just didn't find my sata so i changed it from sata1 to sata3 and then plug it back in,only it was using a multi plug adapater and i heard sissing from it it then the power cut,change the lead and then restart and it load in to bios fine,but when i tried to load up (install window xp) all i could see with pink/blue dot'y lines going across the screen (in place of the blue screen),so basicly i need to know if it is just my gpu (6800 pci-x point of view) that is fried or if it something otehr than that..
(put it here as it's a querre whether or not its the gpu at fault,please move if you think it belongs in different section,thanks )
