Urgent: Help, please!
452 14
Is there anyone here who can bend a prong on a cpu back?
I was switching mobo's and somehow one of my pins got bent, I'm scared that I am screwed >.<
god this sucks, I have a new mobo and ram and I CANT EVEN USE THEM
1 - 15 of 15 Posts
take a quick look at it - is the pin bent all the way at the bottom or more towards the center? If towards the center, you might be able to get away with using needle nose pliers to just bend it
The pin is reasonably flexible except for at the very base (near the solder point)
Discussion Starter · #6 ·
i cant get a clear picture, and they are bend at the top, like, semi-lopsided
and i cant do it myself because I have VERY VERY VERY unsteady hands
I was wondering if anyone here could do it? If all else fails I will take it to my uncles cause he has a huge magnifying glass for electronics
this sucks though, I spent $180 and I cant even use it X_X
I agree with the .5 pencil trick, but, it won't work if it's bent below the halfway mark.
Old School Computer Gamer
Just dont get fustrated get a mechanical pencil and try it out.... No pressure.
1 - 15 of 15 Posts
