1 - 11 of 11 Posts
ok im going to frys in like 30 mins andi was wondering which heatsink/fan is the best cooler and MOST IMPORTANLY QUIET. and it for a 2.6ghz northwood...the most important thing is quiet than its best cooler..currently my cpu is running at adverage of 96ºF.. thanks
I heard that the Zalman7000Cu is very good and quiet. I'm not sure it's 7000Cu, I'll check, 1 moment
Zalman 7000B, that's the name for it.
Originally Posted by thehacker11
well my current fan is running at 50% and i can barely hear it will the zalman run at that speed and be quiet and cool more than my current one?
What's your current one?
You'll definatly get better performance out of the Zalman one and it's as quiet as stock I believe.
Discussion Starter · #8 ·
ya sure it will cool more? and quiet AS stock or quieter THAN stock? and my stock is running at 54% dont forget...so it will cool better than 115 at load and 94 at normal? and should i even get it? will there be any improvements and no i cant oc this much its i can temp oc it to 300mhz more but it dont put much heat on it since i cant BIOS oc it
If you want silence, the Zalman is the best choice and it's all copper so you'll get a performance gain as well. So yes, it will cool better at a noise level of just 27.5dB and that's at full blast.
I'm sure you've heard.. "the cooler the better".. so you'll probably get more stability than using your stock cooler..
1 - 11 of 11 Posts
