1 - 10 of 10 Posts
I need a watercooling kit for my AMD 1090T on a Asus AM3 Formula IV mobo.
Any advice? I prefer a watercooling kit that has everything included
Watercooling Enthusiast
Well, this isn't urgent, but that kit is ok. Don't buy a kit. Piece it out itself and don't be fail. I built my first computer and water-cooled it from day 1. It's not hard
stay away from anything UV reactive, dont use transparent tubbing, stick to Norprene. most kits are overpriced. your better off building something yourself
If you buy that kit, don't use the coolant provided, pick up some distilled water with pt nuke and or a kill coil.
yep, you don't know what you're talking about...
oh and for anyone who says that kit is over priced and isn't that good, part it out, add it up, and look at the actual reviews of each of the key components, THEN say it's not that good and it's over priced.
Discussion Starter #8
It was urgent when I posted it because I was on the phone choosing an alternative to my H50. Oh well
RGB Numba Wan!
for $250-300 you can piece together a better setup imo. the swiftech is not bad if your too lazy to piece one together which could yield better performance. good luck
1 - 10 of 10 Posts
