1 - 5 of 5 Posts
So I booted lappy only to find out that my taskbar is just gone. Its there for about 5 seconds, but by the time all my programs are loaded its gone...is there anyway to get it back? What happend?
ctrl alt del. shutdown explorer.exe then restart it thru the taskmanger (File>>New Task) c:\\Windows\\explorer.exe see if that works
check task manager to see if there are any unwanted processes running. If so report the process name and ill check to see if it is possibly a virus <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
if yu move your mouse over were it was what does it do?
Discussion Starter #5
ok im running a vista theme and its got this weird thing, im taking a print screen of it and i'll try to upload it here from the laptop<br><br>
gah cant access paint!!! When I log onto the other account onthis computer, its there. Just mine its missing<br><br>
GOT IT...<br><br>
It was this weird DOCK program that comes with the Vista theme.....it was taking over my taskbar.....stay tuned may need more help
1 - 5 of 5 Posts
