My computer is totally messed up guys, I'm typing this from my gf's mom's computer. I haven't had my comp for 2 days and I can't take it anymore you guys gotta help me. Ok here goes.....
For months I've been getting random lockups, where any video on the screen and any audio would just totally lockup and I'd have to hold the power button to force it to shutoff. I tried a whole bunch of stuff to try to stop it and it seemed like it stopped for a bit but after a few days it would always end up doing it again.
I tested everything, I tested the RAM and it passed alot of cycles of memtest, I tested the HDDs and they checked out ok. The video card got replaced with a new one from RMA, and I could pass a prime95 test for 12 hours stable easy only to have the computer lockup a few hours later while checking myspace or something small. I set the BIOS to all default settings and it still happened so I know it wasnt just unstable. Well anyway it hadn't been happening very frequently so I kinda gave up tryin to find the cause.
Well then all of a sudden a few days ago it started doing it every few hours, and then even sooner, and finally got to a point where it would turn on and post but would lockup before Windows even booted. It got to this drastic point in a matter of days. I hadn't had time to mess with it untill tonight when I got home from work and when I turned it on the monitor didn't even show anything.
I took it all apart and cleaned it and checked for anything physical I could see that might cause it and didn't find anything. I plugged in just the essentials and no extra cards or anything and tried it again, only to find that now it wont even post. The LED comes on steadily without flashing for a few seconds than shuts off, all the fans keep running and the DVD Rom opens and closes as if it was working.
I cant even tell you what kinda beeps it makes because I have no idea where to plug the little case speaker into the mobo, its not in the manual anywhere and I cant figure it out.
PLEASE just start throwing out suggestions to try to help me out, I need my rig back Im dying here. Ill answer any questions to help get to the bottom of this. I think maybe my mobo is dead/dying but I dont have any way to test it since I have no other socket 775 mobo anywhere. If it is the mobo I can RMA, its XFX and they are great about RMA, but that brings up another problem. They take awhile before they send the replacement and I have nowhere to put my CPU that could keep it safe while not in a mobo. Maybe someone has a
cheap socket 775 mobo I could buy for testing purposes if thats what it comes to. Anything you guys can suggest is very much appreciated, I'm seriously losing my mind over this, it seems like since Im the one in the house that actually knows a bit about computers its always my computer that gets the problems I cant solve
