1 - 3 of 3 Posts
sorry to keep on threading....
1) can uv dye be seen through tygon
2) can you put the dye in via the t-line - and somehow it will flow through the system automatically?
3) typically, with strong automotive coolant dye stuff --- for a short system like mine, does a drop or two of dye usually do it?
1.) If it's the clear tubing, then yes. If it's colored, I don't know, I havent tried it.
2.) Sure can.
3.) Are you talking about WaterWetter? If so, use about 2-3oz. for your entired setup.
1 - 3 of 3 Posts
