I am RMA'ing my motherboard and need to remove everything off of it. I had installed a xigmatek backplate for my S1283. As you know, the backplate has some adhesive that holds it to the back along with some screws. I can't pry the plate off without exerting force which I think would damage the motherboard. How should I go about removing the backplate in a safe way?
Just do it slowly, wriggle it back and forth. Twist it. It takes some time but it will come off. Chances are that the adhesive pad will stick to the motherboard.
Overclock.net
