1 - 15 of 15 Posts
Um, like *in* the monitor, or *on* the monitor screen?
DOn't use chemicals unless it is a TFT cleaner, water (pref distilled) with a cloth is fine.
Ideally, you should turn the monitor off and let it cool, then clean, let it dry and power on again, this will avoid streaks/marks.
Don't press too hard!
Super Moderator
Originally Posted by phz10;15198652
Accidently spat hot heat on my monitor,
what is the best way I can go about cleaning it?
Tools i currently have:
Micro-fibre cloth
Windex
Anti-static, anti fog multi-purpose cleaner
I didn't know there was any kind of other heat
Just use a damp cloth that should do the trick.
Originally Posted by phz10;15198769
Alright thanks, i'll try it, and I meant hot tea ^_^, I was panicking
Stay away from 2 ***** *** cup videos. Then your monitor is safe from tea.
Don't panic nothing will happen tried cola,tea,coffe(accididently) on a notebook nothing happend.After using the hair drying machine it worked like a charm even though short cuts occured in 3 of the situations.
Questionnaire galore!
Nothing wrong with drinking tea... Really... -.-
1 - 15 of 15 Posts
