1 - 8 of 8 Posts
I just finshed installing a new motherboard, video card, and powersupply, everything works fine. EXCEPT when I try to boot with a USB device connected ( MX510 ) my computer will not start up. It goes to the bootup screen shows my processor, and freezes. If I unhook the mouse, and use the PS/2, everything runs fine. Can anyone help me fix this?
thanks
Go into you BIOS, I'm not sure exactly where it will be on your BIOS, but there will be a option to disable USB during boot. Just do that and it will work fine.
I can't find anything about USB booting. I did find a "boot from other device" on my boot sequence page, and I disabled that, but its still freezing.
Find the Plug and Play setting is the BIOS. Set for OS Plug and Play, not BIOS plug and play. Maybe that will help.
Discussion Starter #5
In the "pnp configuration" setting, the only options are -
Primary graphic's adapter - pci/pciEx
Resources controlled by - Manual/Auto
(if Manual )
IRQ Resources Setup -
IRQ-3 assigned to
IRQ-4 assigned to
etc etc etc etc
Maximum Payload Size -
I have no idea about any of those things
Discussion Starter #7
Originally Posted by pauldovi
there is no option to disable BIOS plug and play?
Nope, what I just listed is exactly whats there. Unless theres a way to get more options?
I am not very familiar with MSI BIOS, sorry. Other than what I said the best bet is to update the BIOS. See if that helps?
1 - 8 of 8 Posts
