1 - 11 of 11 Posts
Well, it says please plug into a USB high speed 2.0 port and then it says I don't have any so its taking ages to upload songs to my ipod. It worked fine before I reformated/on old mobo. Are there any?
Can anyone else confirm this?
WindowsXP comes with USB drivers (they work out-of-the-box) so if your MB has USB1.1/2.0 connections they should work, unless the device (your ipod) requires additional drivers, which I doubt. Only thing I can think of is a faulty connection from either your MB or the ipod. Do other USB devices give you the same error?
Discussion Starter #5
Yes, same error.<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Yes there are USB Drivers but they are only for the front panel USBS on your case - and the drivers are for the mobo to reconnise they are connected. You will find the drivers on your motherboard driver disk <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>Mad_Handlez89</strong>
</div>
<div style="font-style:italic">Yes there are USB Drivers but they are only for the front panel USBS on your case - and the drivers are for the mobo to reconnise they are connected. You will find the drivers on your motherboard driver disk <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>If running XP I'm rather certain that you don't need drivers for basic USB functionality for the back or front ports. I know that you do need drivers in Win98. <br />
You can try installing the drivers on your MB installation disk and see if it helps, but if you get errors when connecting devices in any of the USB connectors (test all of them, front and back) chances are they are faulty or some sort of software corruption.
With XP and XP SP1 you may need either the patch or SP2 for better USB2 support.
Try going Device Manager, and uninstalling all the USB controllers, then restarting. Windows will re-install the USB drivers. If that doesn't work, then reset the CMOS, as by bro had a problem with his mouse (would detect everything BUT the mouse). Even re-installing drivers didin't fix it, but reseting the CMOS did.<br><br>
cause_of_chaos
Discussion Starter #11
<tr>
<div>
Originally Posted by <strong>cause_of_chaos</strong>
</div>
<div style="font-style:italic">Try going Device Manager, and uninstalling all the USB controllers, then restarting. Windows will re-install the USB drivers. If that doesn't work, then reset the CMOS, as by bro had a problem with his mouse (would detect everything BUT the mouse). Even re-installing drivers didin't fix it, but reseting the CMOS did.<br />
<br />
cause_of_chaos</div>
</td>
</tr>
</table>
</div>Brilliant! That fixed it. Its uploading so much quick now. Thanks <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 11 of 11 Posts
