1 - 2 of 2 Posts
Hello
My friend put his USB into my other friends mom's computer, and when he opened the USB, there were 4 porn files. When he tried to open one of his school files it said malware detected.
Is there anyway to run a scan and clean a USB device and get the old files back?
· Premium Member
Sure. Make sure autoplay is turned off on the PC you're going to plug it into. Then plug in the drive and run scans on it, I recommend your antivirus of choice and then MalwareBytes. Hopefully the files come back from removing the virus, but if not use Recuva.
1 - 2 of 2 Posts
