1 - 12 of 12 Posts
I bought a used cpu water block the person said they used no dye's but I opened it up and its pretty dirty. I tried cleaning it but can't seem to get all the stuff off thats stuck between the pins is there a method of doing this ? Should I just sell this on ebay and buy something else or try to clean it. The block is a Apogee GTX. I really rather not order another block now till I change my motherboard. Please help
Did you try using it? Give it a try...if it performs well keep it...its not like you can see inside of the block
· Data Recovery Engineer
^^ This. Once your done, make sure you clean it well with clean water.
If it still not coming off, then I would go for a more potent bath of vinegar and water.
1 - 12 of 12 Posts
