1 - 4 of 4 Posts
^^That's my user name^^
Well, I load up fedora linux in graphical mode with my 6800gs, and I get a screen like when you overclock your GPU way too much... How do I fix this? I can use my 6100 onboard ok at 800x600, but thats as good as it gets...
Do you have a different monitor that you could try? I had a problem like this about 8 months ago when I got my 6800GS. For some reason my LCD monitor did that, then I tried the CRT and she worked great. So I put the LCD back on the dell machine where it works fine for some reason. Everyone I ask didn't seem to know why though. Most just be something with the monitor, I not sure of that though.
Hmm, I'll try that when Knoppix is ready. (I'm burning the DVD version of 5.0)
9 Cans of Ravioli
Aha!<br />
<br />
Someone with the same problem as I was having.<br />
<br />
I couldn't get any Linux distro to work with my previous card. (6800GS). Did exactly what you said. Onboard worked fine. 7600GT worked fine. But no 6800GS.<br />
<br />
Just thought I'd throw that in.
1 - 4 of 4 Posts
