I apologize as i'm sure similar ideas have been thrown around a lot, I just cant find them.
I've had my eye on the Kraken g10 for a long time, the fan/mount that allows you to connect their closed loop cooler directly to the GPU die. The issue is, it's circular and my H100 is one square peg. Are there any products or solutions to put my H100 to good use here? Or would have I have to just purchase a circular closed loop cooler to make this work?
I find the prospect of closed loop gpu cooling to be exciting and i'm guessing way more efficient than stock.
I saw that EVGA finally hopped on board the closed loop train recently with dedicated coolers for this task
http://youtu.be/XiyO5XQhDJQ?t=2m56s
I was just hoping I could use my existing (and much better) H100 solution.
