Hi, does anyone use a fan adapter to put a bigger fan onto their heatsink? Reason I ask is I have an Akasa Silver Mountain from years ago with a humoungously noisy Delta screamer (6800 rpm!) 60mm on top... I removed the latter and put on an Akasa 80mm (from an Akasa 827 HSF I think). Just wondered though if the air gap (about 25mm) caused by the adapter between fan + heatsink is detrimental to cooling effect...
On similar note, could you use such an adaptor to put say, a 120mm fan on an Sp-97 HS and would it make much difference either way?
