I'm looking to build a new PC using a full tower case that has 14cm intake fans installed as standard. However, I'm sure the cooling can be improved by adding some more powerful fans.
I was thinking of replacing the 14cm intake fans with AP-15 Gentle Typhoons and using a low profile Bitspower 140mm to 120mm fan adaptor to mount the fans in the case.
Firstly, I know that the Gentle Typhoon fans are regarded as some of the best radiator fans but have do they perform as case fans?
Secondly, does anyone have any experience of using a Gentle Typhoons with the Bitspower or any other fan adaptor to replace 14cm case fans?
James
James
