Using Old Account
318 Views 10 Replies 6 Participants Last post by  blupupher
alright so as you can see ive been folding under Enjoi for team 37726.
I did a complete reinstall of Windows so i had to redownload the client, how do i fold under my name again?
1 - 11 of 11 Posts
You don't have to do anything...just put your name and team number into your client after reinstall.
tray or console
and it will continue from where it was before?
im using GPU2, same as before
It won'tcontinue from where it was before unless you stil have the Work Unit folder and the queue.
For GPU client, it should pop up once you restart your computer and you wil input your username and team number.
For SMP client, it should usually ask you, when you install it the first time or open it first time.
but ill still be rank 440th etc?
Yes ranking will not change aslong as other people do not surpass you in folding points.
If I stop for a day, I'll probably lose like 20 spots
you should. right click on the tray icon go to config
You might even have to copy the DLL files from the appdata/roaming/fah-gpu folder to the program files\\fah-gpu folder in order to get it to work too. I've had this problem with Vista before.
You might even have to copy the DLL files from the appdata/roaming/fah-gpu folder to the program filesfah-gpu folder in order to get it to work too. I've had this problem with Vista before.
I have never had that issue with Vista.
1 - 11 of 11 Posts
