1 - 1 of 1 Posts
Right now I've got two monitors connected to my desktop, of which I only need one in Linux. The other one is going to remain off or switched to a different input every time I'm using Linux. Is there any way to just disable the second monitor?
This is going to be for a Linux Mint 6 x64 installation.
EDIT: Nevermind, I just found it. For those interested, in the screen resolution panel, when you select a monitor and click on the resolution menu, you can set it to off.
1 - 1 of 1 Posts
