Here's this...
http://www.indium.com/documents/appl...otes/98104.pdf
Looks like indium is the way to go, but not sure where to get it or how much it is.
As for adding the solder; carefully. My vision is toget the CPU as close to the liquid solder as possible, then when it sems like the right time to place it, drop it on there, but use gloves and goggles for protection against a potential splash. Also, just like grease, only a rice or pea sized bit will be needed.
As for the cooler, why would I want to reheat the solder? Oh, I think I see what you mean. It's hard to close the little lever on the CPU lock on the mobo with a hulking cooler on it. I guess you could put the CPU in the socket, drop a small amount of solder on there and then put the cooler on. This might be the only problem with this method.
