Can anyone help me find some uv led strips that are either 2pin or 3pin and magnetic? I was looking at the ones Icemodz sells and they seemsto be what I want but do not say how they mount so I am assuming they mount with adhesive but I want magnetic.
I want to wire the strips to a switch so 2pin would be preferred as I do not know how to interrupt a 3pin cable. if anyone can tell me how to wire a 3pin to a switch that would be helpful also.
To sum up-- 12inch or less uv led strip with 2pin or 3pin connector that is magnetic and hoping to daisy chain 3 at a time
I want 6 of these strips
Thanks for any help you can provide
http://www.icemodz.eu/store/#!/UV-Ultraviolet-5050-led-strip-s-2-Year-Warranty/p/52324296/category=5346676
these are the ones I was looking at
Have to head off to work but will check back tonight
