1 - 12 of 12 Posts
Originally Posted by Bazmecc View Post
PhysX scores have huge CPU scores, especially the second CPU score, which is usually over 100FPS then
right, I see what you are talking about now, i got 11.-fps on that one without physx.
does that score 13,691 seem fine for the dual core and GTX260?
Discussion Starter · #6 ·
Originally Posted by youra6 View Post
yes it does. I used to have a quadcore 9950 and a 280 GTX. With that I can only pull off 12.9k
what were your cpu and gpu scores separately?
Did you OC the GPU?
driver 195.62:
cpu-7260
graphics-19426
OC on my GPU's was 756/1512/1188
Originally Posted by grunion View Post
Score looks good, my score no physx/c2d
Thanks for the reply!
I just ran it again with an older driver, 190.62 and got a better score:
http://service.futuremark.com/compare?3dmv=1651310
14,012 marks
cpu-7379
graphics-20006
Discussion Starter · #8 ·
Was that with just one 260? I ran with just one 280 and I got around 12.3k GPU score with a slight overclock. Clocks were 650/1460/1190.
Looks about right to me.
I am using SLI 260's
Yeah than that GPU score is def. about right
If it was a single 260, I would be worried about my scores lol
I dont know how well a E7200 benchmarks, but from your CPU scores, I can tell its holding back your performance.
My 9950 @ 3.2ghz 1.42 volts got a score of 10,000+.
Then again I could be dead wrong
that is my main concern actually, this little chip has been great and has been clocked to 4.0ghz for ~18 months now. I would really like to go PHII 965 but it's damn near impossible to find an AM3 board that does SLI.
ill tell you one... the one im using right now
if you are looking for a "true" AM3 board with DDR3 support this one will do. I guess the one I have isnt a "true" AM3 board cuz it only has DDR2 support
here is the real AM3 board: http://www.newegg.com/Product/Produc...-236-_-Product
Discussion Starter · #12 ·
awesome thanks!
1 - 12 of 12 Posts
