1 - 1 of 1 Posts
Vantec Tornado 92mm Double Ball Bearing High Air Flow Case Fan - Model TD9238H
Description:
When it absolutely has to be cool, nothing beats the Vantec Tornado Case Fan. Vantech's Tornado TD9238H case fan is a powerful cooling solution for today's desktop computers. The dual ball-bearing design extends the life span of the fan and keeps it spinning at 4,800rpm. It can be easily installed in a wide variety of desktop cases and yet is capable of pushing more than 100% of the air than a standard 92mm case fanâ€"whether it's used to pull cool air into your system or push hot air out. The fan can connect to your motherboard's standard 3-pin fan connector for power or the optional 4-pin cable allows you to connect this fan to your power supply. Perfect for gamers and overclockers, the Vantec Tornado Case Fan is a no-compromise solution to overheated computer woes. Type: Case Fan Bearing Type: 2 Ball RPM: 4800 RPM Air Flow: 119 CFM Noise Level: 56.4 dBA Power Connector: 3 / 4 Pin Color: Black Compatibility: Case
Details:
DetailValue
ManufacturerVantec
ConditionNew
Model NumberTD9238H
ClassificationCase Fans
1 - 1 of 1 Posts
