1 - 2 of 2 Posts
Has anyone used or had any experiences with the VapoChill LightSpeed.
http://www.vapochill.com/main/page.asp?sideid=469
And if so are they good experiences. I only ask because I like to hear what other people have to say before I buy.
Cheers people.
Cheers people.
A Manc!
I haven't used them personally but from what I've picked up on Phasechange forums. Theyre a very good unit though not as good as the Mach II GT. If your after a unit it's pretty easy to pick something up on the second hand market. You can usually get something like a Mach II for £350 and if you wanted have it regassed to r507 (obout £100). Then it's the coldest phase change out their. A guy on another forum's idle temp when overclocked to 4 Ghz is -68c. That's better than a GT never mind the LS.
So get you feet wet for around £350? it's not bad is it.
1 - 2 of 2 Posts
