Table of Contents
June 14 - Some misc parts I have so far
June 15 (1) - Cutting out the window
June 15 (2) - Removing the HDD rack and fixing the front mesh
June 15 (3) - More case cutting, fan holes, cable management etc
June 15 (4) - Case cutting continued
June 16 - Cable management and wiener dogs!
June 16 (2) - Modding/painting the Accelero GTX 280 GPU cooler
June 17 - Weathering/rusting the GPU cooler and testing the "Sophisticated Finishes" metal paint
June 20 - Painting the case frame!
June 20 (2) - Second coat of primer
June 25 - Interior is painted!
July 4 - The frame gets its rust treatment. As well as the CPU and GPU coolers! (and underdog makes a guest appearence)
July 4 (2) - The final rust shots for the case frame and coolers!
July 7 - Making the copper nails into ramsinks for the GPU memory
July 26 - Bending copper tubing to run the fan wires!
August 4 - Still working on the tubing. Also fabricating the front 140mm fan mount.
August 23 - Cutting the acrylic window and installing it!
August 29 - Bending the front and rear fan tubing and finishing the front 140mm mount
August 29 (2) - Modding continued.
September 1 - The tubing gets plumbed into the controller box!
September 9 - Moar plumbing parts and the fan controller still coming together
October 29 - Still working on the fan controller->optical drive piece and the copper tubing AND (in a RL update) I GOT ENGAGED!
December 19 - WATERCOOLING and hardware finally going BACK INTO the case! Part 1 Part 2 Part 3
March 14 (2011) - GPU goes underwater. Spring returns, Repo gets settled and plans to start modding more frequently.
March 18 (2011) - Fan controller mod - Biggest hurdle is over. The wiring can begin!
September 2 (2011) - RUST IS HERE
